Code3 Model 3600 remote siren manual/wiring
Benno
370
Germany
Hello,
I have two Code3 Model 3600 remote sirens but no information about it.
Does someone happen to have a source for the wiring/manual for the Model 3600 remote siren of Code3?
Thanks in advance!
All I know it is a remote Vcon and is extremely rare. I don't have a diagram for it but I have a pretty basic understanding on how to wire it. (Connecting the control head and powering it on). I drew some basic areas on where to wire and put in the cable. I don't know what the 2nd auxillary cable does though. Hope this helps.
Benno
370
Germany
Helps a bit, thanks.
But I`m still wondering how i can use the slide- and aux-switches.
Or are there still parts missing?
Nolines
1,681
Margate, FL
Close as I could get, how's about a serial number or something to be able to search by, part number, better model info need a starting point...
  • InstallManualV-con.pdf
Benno
370
Germany
The V-Con looks similar, but is not comparable and also has more screw terminals on the back.
That's all it says:
Nolines
1,681
Margate, FL
I know I've been searching and having trouble finding the exact model, someone may have info. Have you contacted code3 directly?
Nolines
1,681
Margate, FL
So at that point it was code 1 by then? Lol hopefully they have it still, just hard to believe that it wasn't part of the PDF of the original unit.
Nolines
1,681
Margate, FL
Well that is what popped up when I was searching, model 3600 has so many iterations the vcon was what came up that's why I kept going at it hoping there was some sublisting for the remote head... Annoying!
lite-em-up
116
Eastern Missouri
That's a 3600-A-7. Did you ever find the manual you were seeking? I have one if not. You are missing the power distribution centers. That model used two of them. One for the slide switch and one for the push buttons. Each PDC had 4 relays. The PDC for the slide switch used 3 relays for the 3 levels on the slide switch, the 4th was used for a horn ring transfer relay. Great systems. My all-time favorite from the Code.
Benno
370
Germany
... Did you ever find the manual you were seeking? I have one if not...
No, I haven't been able to find any instructions yet. Do you have the manual in paper or as a file?
That's a 3600-L7. .... You are missing the power distribution centers. That model used two of them. One for the slide switch and one for the push buttons. Each PDC had 4 relays. The PDC for the slide switch used 3 relays for the 3 levels on the slide switch, the 4th was used for a horn ring transfer relay. ...
Ok, thank you for the information. I had already feared that parts were still missing.
Are the power distribution centers described in more detail in the manual so that you could recreate them?
lite-em-up
116
Eastern Missouri
I have them in paper form but I can scan them and send to you.
It's been a minute or two since I looked at them. I'll first have to locate the book and then I'll scan. I'll also take a couple of pics of a PDC for you.
lite-em-up
116
Eastern Missouri
Here is the manual. I will look to see if I have anything else. Sorry about the quality. The higher resolution file is too large.
  • Code3 3600 Manual low res.pdf
htamboli
