Custom Flat-Top Mini MX (2100/RX2700/Ranger Bar Clone) *Back to just a 36" bar*
May 25, 2010
7,072
Tunkhannock, PA, USA
Well, I got the idea from .  And since I have 3 MXs hanging around my place, I Decided to construct a custom bar...
First, I started with my custom LOADED 36" MX
Specs:
- 6 Rotators
- Intersections sweeps
- Front Flashers
- Take Downs
- Alleys
I took the top domes off and removed the rotator trays and removed all the halogen lights from the lower section.  Then I took the myriad of Fed Sig Solaris heads I have and started filling the base and came up with this...  Yes, I'm well aware that the inner heads are angled, the lighthead is hitting a part of lens...  I may correct this in the future, and I may not...
I wanted to do something "different" with my intersection sweeps, so I got to thinking...  This is what I came up with...  A Feniex Apollo F6 mounted to the reflector.  After a little flattening of the reflector, I got the light top mount on it nicely...
And it fit well in the bar...
Then I needed to test to see if it would sweep without any interference...
Now I just REALLY need some tops and some 2100 feet.  I'm still trying to decide how to run the 12 Solaris heads in the bar...  I have a Fed-Sig Intelli-Flasher pre wired to run 10 heads, but I also have a ULF-44 floating around I could use as well...
I'm also thinking about getting another pair of Apollo heads and putting another pair of sweeps in this bar...  Thus giving me 4 sweeps at the corners and 8 Solaris heads (4 front 4 rear)
C17LVFD
Harrisburg, PA
That's awesome! Great ideas and execution! The MX platform is so versatile.
Does the weight of the F6 sound like (motor under more stress) it's going to affect the sweep at all? I know the F6 isn't heavy, but the sweep is made for a bulb versus an entire lighthead in it...
Love the 4 sweep idea. Keep us posted on your progress!
Seth
May 25, 2010
7,072
I hooked up 10 of the 12 Solaris heads just to get a taste of what it'll look like...  and I dig it...  lol
I don't think so...  There is a little bit of a rattle, bit that is the F6 wiggling between the flange and the reflector...  I didnt want to tighten it too much and risk stripping out the screw or anything...
wilsonbr90
1,427
Corning, New York
I wonder how a TIR style light would look a opposed to the more linear style of the Apollo. Don't sweeps usually have a more focused light pattern?
Reactions: JohnMarcson
May 25, 2010
7,072
True, but having a 180 degree lighthead oscillating 90+ degrees gives a hell of a light spread...  lol
I'm moved on to stage 2 of this project...  I'm taking all the heads out of the 36" frame and putting them into the 48" frame...  lol
May 25, 2010
7,072
Not sure if I'm going to use this option or not...  It may be too big for what I'm looking for, so I might go back to the 36" frame...  But it gives me something to do to pass the time...  lol  I'm REALLY thinking about doing 4 of the Apollo Sweeps though...  Just gotta save up for 2 more Apollos...  lol
In addition to the 8 Solaris heads and the Apollo Sweeps in the bar currently, I still have 8 more Solaris heads and 2 Mini LED3s...  lol  I'm going to want some sort of TD lights as well, just not sure what...
Reactions: Mrlunchbox
May 25, 2010
7,072
Thanks guys...  I'm thinking I'm going to use the 36" frame for this...  It'll fit between my roof rails as apposed to the 48 having to sit above the roof rails...
Again, its just a project, and may not even make it to the roof of my Durango...  lol  I think I'll do a little more playing around tonight...  If I take the sweeps out of the 36, I can get 16 Solaris heads in the bar...  if I use the 4 sweep idea, i'll only be able to get 8 Solaris heads...
Decisions decisions...  lol
May 25, 2010
7,072
This is what I'm thinking now...  lol
Maybe I'll save the Apollo Sweeps for another project...  lol  I'm so indecisive on my lighting projects...  lol
May 25, 2010
7,072
After the multitude of configurations I've laid out, I decided to go with the first set-up...
Front:
- Custom Feniex Apollo Sweeps in the front corners, Blue
- 2 front facing Fed-Sig 6-LED Solaris heads, Blue
- 2 angled Fed-Sig 6-LED Solaris heads, Blue
Sides:
- Fed-Sig 6-LED Solaris head, Blue
Rear:
- 4 rear facing Fed-Sig 6-LED Solaris heads, Blue
I'm still deciding how I want to wire it...  Not sure if I want to use an I/O Board of some sort, or direct wire it...  I'm also thinking that I want to mount my Feniex T-1000 to it as well, but that will have to wait until I get some mount feet...  lol
May 25, 2010
7,072
Me too, but I don't have the funds for 2 more Apollos...  lol  I don't even know if I'll have funds to complete the bar yet...  lol
Storm4200
2,912
NJ
This is great. Love the sweeps. Toss some amber in the rear.
Also, if the sweeps were SMART SWEEPS, you know, the ones that would do intersection warning, and then become TD or Ally lights? How cool would it be if when you activated the TDs, the blue sweeps would become white steadyburn, and stop sweeping...
Just an idea
Reactions: TritonBoulder47
May 25, 2010
7,072
Just an idea
I had that exact idea while building this...  If I can find a set (or two) for a decent price I'd try it...  But then I'd have to buy 4 Apollos...  lol  Or maybe 4 Cannons...
Damnit man!!!  Now you got me thinking again...  lol
Reactions: Storm4200
May 25, 2010
7,072
I dunno...  But its always fun to try new things...  lol  I think the Cannon 360 would work well in any halogen reflector...
Storm4200
2,912
NJ
I think you omit the reflector, kinda how you aren't using it with the Apollo. Just remove the reflector, and attach the cannon to the directly to the mechanism. I THINK it MAY work a bit better than the Apollo, but the only way we'd know for sure, is trial and error.
Phoenix_Rising
Feb 27, 2012
6,742
Berks County PA
I will disagree on that: IF he opts for the cannon, Id argue that itll be twice as effective with the reflector. I can see removal of the reflector for the Apollo possibly, although there too I can see arguement for keeping the reflector, flattening/straightening it out to more evenly distribute the weight of the Apollo. I say this because IIRC the sweeps are a single arm mechanism. Maybe I missed the details of how Tim intends to mount the Apollo on the arm in the thread, but shy of having a straight backed mount plate attached to the arm, I fail to see how the apollo head would move as he wants it to. Food for thought.
Reactions: tsquale
May 25, 2010
7,072
Well, in the case of the Apollo Sweeps, the reflector was "flattened" to create a mounting surface for the Apollo...
If I were to try this with a set of Cannon 360s, I'd utilize the reflector, just make the bulb opening bigger to accept the lighthead...  Like I said, I may or may not even try this...  I need to acquire funds to pay for some tops and mount feet...  lol
7,072
Well I got this bar just about done...  I mounted the Fed Sig Intelli-Flasher in the frame, ran all the wires and cleaned them up, got a 6 wire cable for it and everything wired up.  Just waiting on some tops and feet, which should be arriving today...
The next thing is trying to figure out how to mount my Titan T-1000 to it and get some magnets for it.  Then it may find its way onto the Durango...  lol
Storm4200
2,912
NJ
Absolutely love this build boulder ! Are you not gonna do any amber?
May 25, 2010
7,072
I don't have any amber heads currently (other than some Whelen CON-3s, but then I'd need to fabricate a mount for them)  I do have some Solaris heads that I need to send to Wilson and some of them may get swapped to amber...  I also noticed that I have a few "not so deep" blue Solaris heads in the bar currently that I thought about sending to Wilson as well, but I don't feel like dropping that much coin into this bar...  lol
I still have to figure out how to mount the feet I got to the bar, then figure out how to mount my T-1000 to the feet...  lol  The lights on the feet don't work, not sure if the bulbs are blown or there is a wiring issue.  At least I have a project for work this week...  lol
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
First of all, I love the concept and the execution. The lower half of the MX is under used.
I also thought the apollo would be too wide an optic to "pop" in this application, but the video seems to show some "pop".  Still, I'd like to see a side by side.  Videos are very subjective, this is a great chance at a "frame of reference" type video.  I'd really like to see a video with just the intersections, but where one is an apollo and one a TIR style LED, to compare the optics in this application.
7,072
Thanks boss man...
I do have another MX out in the work shop shed that has 4 sweeps in it...  I can steal a pair and try the TIR head version out, since I have a pair of SOS Mini LED3s that I can play with...  That'll give me a project for work this week...
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
Thanks boss man...
That's great!  I can't wait to see the results.  The apollo looked way better than I expected in that role, the comparison will be interesting.
May 25, 2010
7,072
Or course the TIR head will have more "pop", but I was going more for coverage area...  And a 180 Degree lighthead on a 120 Degree sweep gives tremendous coverage (approximately 300 degrees)...  lol
Reactions: tsquale
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
I just didn't expect the apollo to work in that setting at all.  I'm pleasantly surprised, just don't have a TIR frame of reference.
May 25, 2010
7,072
I didn't get a change to get out to the shed before work tonight...  Hopefully I can snow throw a path tomorrow and get the parts I need...  then I can get a contrast/compare vid up...
May 25, 2010
7,072
Ok, so I got out to the shed to steal some sweeps from my other MX, and here is the result...
I did the same as with the Apollo Sweep, ("flatten" the reflector body, screw the SOS Mini LED3 to the reflector) they just dropped it in...
As suspected, the TIR-style SOS Mini LED3 had a better "pop", but the Apollo had more coverage.  (Of course, the Apollo is also much brighter, but with twice as many LEDs at 4 times the power, thats to be expected...)
And without further adieu, the video...
cawensel
