Damega engineering mini ultimate 100w siren
Ross124
3
Ohio
I have a damega siren with a separate box for speaker wires and + - wires to hook into. I'm getting power to that box and each post that the siren wires go into but no sound coming out of the siren. If I hit the + - on battery it makes the normal pop sound so I know it works. There is + - wires on the actual siren box that i have hooked up and there is also 2 green wires that just say siren on them where do they go?20201029_204213.jpg20201029_204150.jpg20201029_204208.jpg
This is what I'm working with.
carguy411
372
ny
The green wires go to the speaker. How are you hearing a pop of speaker isn’t connected. ?
Wow seems like they copied the 4200
carguy411
372
ny
I hear the popping when I gold the speaker wires on the positive negative wires that run to the battery
Little confused you have the speaker wires going to the battery terminals ?
Ross124
3
Ohio
No I have the speaker wires ran to the siren box. Only time the speaker wires was on battery wires was to check and make sure I heard noise coming out of the speaker to make sure it was functioning
EMT-BLS
2,640
Waterbury, CT
Red goes to power, black goes to ground. Green x 2 go to the speaker. Gray - yellow are your siren activation tones - touch them to power to activate a siren tone.
StormChase85
