JohnMarcson
I have a strobe arrow bar powered by a Whelen UPS 690 (newer style). The arrow functions are fine, but the "warning" pattern within the arrow mode is pretty bad. I ended up using a relay to put the supply back into "regular mode" by removing one of the three pattern wires required to place it into arrow mode.
Usually once in arrow mode (all three pattern wires powered) the blue and green wire do arrow functions and the yellow does the warning pattern. You place the supply into arrow mode by powering all three pattern wire at once. I hooked the pattern wire I wanted to disable (gray) to the normally open side of a relay and the trigger to the yellow wire. Now when you power the yellow wire it powers all 6 heads (I have the progressive switching enabled and yellow turns on all heads) but it also removes power from the grey pattern wire. This drops the supply out of arrow mode back into regular mode, action flash. Probably not necessary just to get a better warning pattern, but I hate the warning pattern in arrow mode. I am editing a video.
b
b
