Direct Pattern Input from ERM
May 16, 2010
2,340
Torrington, WY
Title/Name of item - Direct Pattern Input (DPI) Flasher
Manufacturer - ERM
Model Number - DPIF01
Link to manufacturer - ERM's Programmable Flashers
How/why you got it - Demo Model
Purpose/Description - I had the opportunity to demo the DPIF01 Flasher from ERM. When it arrived I opened it up and found the flasher with the install instructions. I read over the instructions and I like how detailed they were. They showed you how to install the flasher on both a negative and positive side vehicle. I installed the flasher on a 2003 Ford Escape which happened to be a ground sided vehicle. It took me a total of 15 minutes to install. The programming of the flasher was really easy too. I set up the way I wanted the flasher to flash and away I went. The thing I really like about the flasher is being able to see the pattern on the LED indicators before I set it. I also like the ability to program a flash pattern that is different from any other HLF that I have seen out there.
Here are the specifications from the website.
First ever programmable multi-pattern headlight flasher (patent pending)
Easy to program
Flash pattern is what you enter into the flasher's memory
Can record up to 45 seconds of inputted data
Flasher immediately plays back the pattern you just programmed
Can be installed into either Positive Switched or Negative Switched Headlight Systems
Very detailed instruction manual explains how to correctly identify your vehicle's headlight requirements and how to properly install your flasher (not your typical 1 page manual)
Designed for 12 Volt DC electrical systems
Each relay can handle up to 10 amps
Weatherproof design
Dimensions: 4.1" L x 2.1" W x 0.9" H
Overall I think this is one of the best HLF on the market. I would recommend this flasher to anyone.
Rating
•Durability 10
•Performance/Usefulness 10
•Innovation 10
•Appearance 9
•Price 9
Picture(s)/Video(s)
Videos:
kiemartin6
