DIY led 3 module high power leds 12v-24v less than 6$ per module
ambu4100
247
belgium
hi all
this trick because i d like to remplaced my vista lower section in leds ( i have halogen at this time )
i buy all on e bay in china by merryday168
3 leds pcb , 1w led emmiter and collimator
i buy also lm 317 regulator and 38 ohm 1w resistor
all cost about 6$ for all
first : i weld all my led in pcb in serial +/- +/- +/- and i paste emmiter with glue
second : I connect negative pole on ground
I connect positive pole on pcb RED ( see pics added) and relayed on lm 317 with resistor
POSITVE OUTPUT IS AMBER (see pics)
i applied 12v or 24v and run
this is a simply module steady burn version and requered a flasher
drive all 1w or 3w power leds color
i built a signalmaster with ( send me your mail if interessed)
thanks for reading
FFParker
1,095
Aiken, SC
I guess the question I have is could you provide links for the parts or at least to the dealer. I am very interested in making some led strips my self. Thanks. Looks great.
dwk270
237
Oregon
Looks very nice. Think you could make up a smaller version for a dash light?
ambu4100
247
belgium
i understand
to buy for merryday , i see if you buy per lot min 10 panel ,min 20 leds and dissipator and in electronic store lm 317t with 38ohm resistor
retail price per piece about 6$ per module complete
for lm 317 regulator , it s not very warm because he regulate from 12v --)9.6 volt
i buy for about 100$ for custom module for vista full leds homemade
see below youtube
chief1562
5,840
Slaterville/NY
All the videos seem to be inside with lights off.
Can we get a video of it outside in the daylight?
Ragnarok
