I have two old strobe power supplies. They are, I think, from the mid or late 80s - VAMA units, from before FedSig acqured VAMA. One is a 2-outlet and the other is a 4-outlet. They both work just fine, double flashing, but the flash pattern is very slow.
A technical question: would it be possible to connect both outlets to the same strobe light, to get a faster pattern? The output alternates between the two outlets, doesn't it? And I'm guessing all wires wouldn't even need to connect - one ground would be sufficient for the strobe light?
If this works, then by extension the 4-outlet could become a 2-outlet with a faster pattern? Or am I just going to cause a mushroom cloud if I try this?
Hopefully my explanation makes sense.
