Dual Talon Sync Question
Bigassfireman
823
U. S. of A. Ohio
OK, so I know I saw this question before, I searched, but can not find it. So, if anyone can link me to it or just answer my question, then thank you.
Is there an easy way to sync two NON sync dual talons together? I do not want to add a flasher and put them on steady burn. I would rather be able to open them up and add whatever wiring inside that may be needed if at all possible. If not, I guess I'll be stuck with two lights flashing independently on the dash
3,834
New York City
some say there is a way, i never found it.......... flasher and steady is the only way i know
May 25, 2010
7,072
Tunkhannock, PA, USA
If they are set-up like the singles I've opened up, there should be a small hole next to where the power and ground are soldered onto the board. That open hole is for the sync wire... I've never done it, but in theory it should work...
evanf3
80
BBurg, VA
I have never heard of one. You could try to wire each lighthead up a flasher individually if you want to go that route/
May 25, 2010
7,072
Thats up to the end user... I'm not saying yes and then have someone blaming me for ruining their light...
911
3,834
New York City
i dont think it would work too well...........either buy sync talons , use a flasher and steady burn , or leave them un synced
ac316scu
82
Westchester NY
I've noticed this too but never tried it. Can anybody confirm or deny this?
shues
NW Indiana
The sync-model Talons have different patterns than the non-sync-model. This makes me think there is more going on here than a just a cigar cord versus a 3-wire pigtail.
Bigassfireman
823
U. S. of A. Ohio
I guess I'll use the same pattern for both light and try to get power to each at the same time so maybe the pattern will be fairly close.
shues
NW Indiana
In my experience, that works for only the first ten or twenty seconds before they get out of sync and begin to muddy your warning signal. After seeing that and contemplating it for about three days, I broke down and bought a pair of sync dual Talons. I couldn't be happier with the results!
Steve0625
1,213
Northville NY
I suspect that the hole for the synch wire is there on the non-synch models because the manufacturer buys only one version of the plastic shell. It would be much more expensive to purchase different shells for each model when the only difference is that tiny hole.
May 25, 2010
7,072
It has nothing to do.with the housing... The extra hole is on the control board in the lighthead...
Jman423
Sep 10, 2010
3,391
United States
fire1 said:
You can get your best answer by call tech support at whelen. If it can be done, Bruce will tell you how.
Somehow, I don't see Whelen Tech Support promoting this type of activity.
I've called them and asked for simple "outside the box" input about adding LR11's to the spacer area of a Liberty and they told me it couldn't be done... yet there is a thread here where someone did it with stock parts. I think they just stick to the script.
fire1
621
Michigan
He has always given me a straight answer on things that should not be done outside the factory. I am not a dealer but have worked with for years.
Steve0625
1,213
Northville NY
Oops, my bad, I could have sworn someone said "case."
But, same,same. It is likely that they use one pc board for two or more applications in the Talon. Just different components or wiring changes. The older Dual Dash King strobes are like that.
Jman423
Sep 10, 2010
3,391
United States
What makes me skeptical about this working is that the patterns are different on the sync model. While the board might be the same, the programming likely isn't. It would be great if someone could confirm this one way or the other.
ford-dealer
857
San Antonio
In Reply to your post #149614
I can CONFIRM this does NOT work. I did it myself. Also if you notice, the SYNC versions have Phase 1, Phase 2 of each flash pattern, unlike the NON-SYNC versions. The Phases make it possible for the SYNC process to work. I only noticed that AFTER I attempted adding the 3rd wire to the board(s).
ac316scu
82
Westchester NY
cool thanks
Bigassfireman
823
U. S. of A. Ohio
I'll have to live with that or just use one, money is non existent right now, so buying two new lights is out of the question.
shues
NW Indiana
I bought mine here, used. I paid less for both of them than one brand new one goes for.
Jtajk1995
43
Van Buren, Arkansas
Can you share with us exactly what happened?
JohnMarcson
May 7, 2010
10,976
Northwest Ohio
If I remember, nothing. The hole in the board is purely there because why buy different boards. You need the synch style "guts" to synch. The extra wire spot doesn't do anything if the light isn't loaded with phased flash patterns which are Whelen's synch system to allow for simultaneous and alternating.
Reactions: Jtajk1995
Jtajk1995
43
Van Buren, Arkansas
Well don't that just Suck. But thank you for the heads up.
JohnMarcson
May 7, 2010
10,976
Northwest Ohio
On the plus side the steady burn ability means you can use and external flasher.
bjwilliams
