EPL8000 wiring diagram needed...
Minnesota
I just picked up 2 rear EPL8000 lightbars. I was told the internal board has a pair of dip switches, curious as to the functions that they set. I understand the external wiring but the pattern selection is significantly less then the front version. I presume the dips are related to either voltage or patterns.
I did look on the Soundoff website. When I searched epl8000 it said 0 results. Ill email them in a few days if someone does not chime in here first.
Minnesota
Got what I needed from Soundoff. The attached file is for the rear version with arrow.
  • EPL8000 Rear.pdf
Reactions: Tony P
GSPS629
