Federal Signal PA300 Mods
Roofsopen19
16
New York
Good Afternoon,
My question is in regard to the notorious & highly demanded FDNY Spec Federal Signal PA300. I own 2 and would consider opening one up for a look around depending on the input of this thread.
It's 2020...I'm sure someone has had to of tinkered with this unit by now. Does anyone have any experience modifying resistors/capacitors (or whatever the appropriate part is) of a stock PA300 to create or duplicate this desired output tone (FDNY Spec)?
Looking forward to some interesting discussion.
Thank You.
MtnMan
1,533
Eastern PA
Based on the the available documentation and my experience, the FDNY PA300 is a 200W version, with variable resistor R57 set for a higher pitch range (1,800 Hz peak instead of 1,575 Hz) and no connection at the Hi-Lo position of the function switch. That's all, folks!
Roofsopen19
16
New York
Interesting. Thank you for sharing this. My next question is...can resistors be swapped out or modified to “colon” or reenact this desired tone?
Aug 25, 2016
150
NYC
Weirdly I think mine might be 100W, not sure though because I always run it through a couple of resistors so I test it in indoors
CHIEFOPS
1,533
NYC
Isn't the wail cycle a little longer on wind up with a shorter wind down than the standard PA300?
Reactions: Christian Garcia
Wailer
2,294
Canada
I don't think I ever got to hear one. FDNY always runs their sirens in manual mode.
StormChase85
