Hi,
Im about to buy Federal Signal Vision lightbar together with the original Vision controller head (or how its called). Unfortunately, the amp that comes with that is broken (let just say, it totally written off).
My question is: Can I use some other amp like random SM2000 for that? Or I just need the original one.
Im restoring/building CVPI from the NYPD, and the lightbar is the crucial part of it
I still dont quite understand if the brain of the lightbar is in the control head, or in the amp. In the documentation I found that it should be compatible with other amps that have the same connectors, but lets say, if you make documentation in 2000, that doesnt mean its still valid with equipment from lets say 2020.
Thanks for help!
Thanks for help!
