Federal SS2000 output transistors.
billforbush
313
Northern Michigan
I have a SmartSiren that works perfectly except that it seems quieter than it should. I disconnected one 100w speaker and tested the AC voltage across the line - 11 VAC. Is it likely to be the output transistors? And if so, where can I buy new ones? Any help appreciated.
MtnMan
1,533
Eastern PA
The output voltage should be 32 VAC, measured across the blue and brown speaker wires. Try checking it again with both speakers disconnected.
It might be a bad output transistor, but they usually fail with a short or open. It would be an unusual failure mode to produce low output. Replacement is a BUT70W type.
billforbush
313
Northern Michigan
Thank you. Will do
GSPS629
