Feniex Cannon 360 LED Hide-a-way
Tom@Feniex
54
Austin, Texas
I'm not going to lose sleep over it. I just can't believe they are so inconsistant with firmware.
As you are pattern cycling through you stop at the first brake mode/ steady on. Take power off and reapply power to it. You should see that brake mode will flash 2-3 times and then steady on. The next pattern after that is a true steady on. Let me know of your findings. Thank you
acs680
220
Tennessee
You're right, I wasn't removing power to see the brake mode. However, in my 120's from earlier this year, brake mode showed just by tapping the pattern wire. Thanks...
TheCrownie
305
Ohio, USA & Germany
Are those brighter than Whelens old Universal LED Hide-A-Way?
They follow the same Idea. Does anyone know how good the output is at daytime, especially compared to strobes?
I'm sure I'd use a 360 in the crown vic corner light assembly but what about the tail light? 360 or 120?
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
360 in the crown vic tail would be best depending on location of drilling the hole
crt6mrt-265
800
Central NJ
any input on the 360 or the 120 in crown vic front corners?
dovy6
206
Brooklyn
Any recommendations for the Police Interceptor Sedan / Taurus?
Pre-drilled, or at least I can see a hole. Haven't removed the light yet to see what's actually going on there. Thinking Red behind the red filter and Blue for the clear ones. Also a White pair for the front headlight pre-drill hole.
360s, 120s?
Thanks
@thebluesignal
