feniex cannon sync reverse lights
JPate
2
Pearland, Texas
I have a 2010 Tahoe and just picked up a pair of Cannon 120 R/W & B/W that I am going to mount in reverse light housing. My question is how do you set them up to flash when on warning mode and then act as an axillary white lights when the vehicle is put into reverse? Any help would be greatly appreciated.
Nathan R
Mar 27, 2014
853
USA
Did you read the Instructions?
http://www.feniex.com/literature/Cannon non marks2056661839.pdf
The 3 wires are color-coded for priority override:
Wire: Function:
Red: Positive, Mode 1
Yellow: Positive, Mode 2, Overrides Mode 1
Green: Positive, Mode 3, Overrides Mode 2
Therefore Mode 1 and Mode 2 can be set up for 2 different warning patterns, and you would need to make Reverse Mode 3 (to override both warnings), and make the pattern steady burn on White lights only.
JPate
2
Pearland, Texas
So in order to do that, I would attach the green wire to the positive factory wire for the reverse light?
StEaLtH2
2,159
New England
But first you must set steady burn white to that Mode.... Set your patterns first, will be much easier that way.
Reactions: RIG755
dariusz
