Feniex One & Quad Surface Mount Lights
jscollin
1
connecticut
Has anyone wired feniex quad surface mount lights to a feniex one controller yet? All the wiring diagrams for the surface mount lights do not specify which wires to connect to the controller & where. For example, my quad interior bar has only 4 wires. Power, ground, and a white & green wire that connects directly to a specific wiring harness that comes with the F1 controller. I have emailed Feniex but am still awaiting a response.
monfmonf
13
CA, United States
I'm assuming you have the standard QSM (Quad Surface Mount) and not the QSSM (Quad Serial Surface Mount). The QSMs have 3 trigger wires, a color change wire, a sync/pattern change wire, and a ground. I have attached a picture showing the wiring info.
As for connecting it to the Feniex One controller, you can use any of the 32 standard outputs to power any of the 3 trigger wires.
I hope that helps!
EMT-BLS
2,640
Waterbury, CT
Well, no one has the QSSM yet (as far as I know), so they get wired like regular lights. Each trigger goes to an output and powered on with 12v. The Quad ILB is a serial controlled product, which is why it goes direct to the One.
woobatu
