Feniex Quad Question
xcharger95x
26
NYC
I was looking into the Quad 200. Now I know I can select the color I want to run, question is, is it possible to assign a color to a specific light head?
So instead of R-R then flash B-B, What I want is R-B.
Is this possible..?
May 5, 2011
49
US Mid-WI
for any of the products where they bundle 2 lightheads into the same housing, all they do is crimp the harnesses together with a pigtail going out of the housing. That is why when you work with the sync option, one lighthead is red and the other is blue. they already have the sync wires crimped together.
So if you really wanted one of the modules to have a different color, you'd have to disassemble the unit, then cut the wiring setup so you could individually work with the module.
GSPS629
