FEVER Installs: 2015 F150 Green/White
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Grill:
-2 Green T3
-2 White T3
-4 L-Brackets
Fog Lights:
-2 Cannon 120 (Green/White)
Modes: Green/White Flashing
Reverse Lights:
Modes: Reverse (Brake Pop Steady White) , Rear Work Light (Brake Pop Steady White) , Steady Green, Green/White Flashing
Just a toy for the customer that has his truck at a lot of events for his company.
bobbyj
298
Bellingham, MA
Looks good. Upfitting my new 2016 right now.
For the fogs, how'd you mount? Did you replace the OEM bulb? If so, how much light does the white throw at night? Enough to light up ground sufficiently? Also, did you remove the housing to install them?
Also, why not use the 360s in these housings?
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
The customer wanted Green. I only ever had the cannon 120 made in the Green/White Combo. The cannon 120 has a more significant range of uses than the 360 so when we had a custom run of the Green/White run I elected for the 120. I don't think you would have seen much better output with a 360 in this application.
Front fog lights are mounted from the bottom. They are not good to be used as fog light replacements.
bobbyj
298
Bellingham, MA
Thanks Nic. Would you mind sharing how you accessed/mounted the cannons in bottom of the fogs? Looking to do the exact same thing on mine, but didn't seem very easy. Feel free to shoot me a PM if that is more preferred.
Thanks for your help.
-Brandt
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
You have to remove the light then cut the fog light housing bucket in the bottom section to make room for the cannon. It takes some work but doable
Reactions: bobbyj
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
It's not super easy. Gotta unscrew it from behind then gotta be able to release all of the tabs holding it in place as you slide it out through the front
chusen bucher
24
woodbury, ny
hi sorry for waking up an old thread. im doing my 2016 f150 this weekend and id like to know if i should rather add the cannon 120 from the bottom of my reverse light or will it work fine if i replace the factory bulb? any help would be appreciated
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Replacing the factory bulb was fine for these.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
We used 120's since it was aiming straight back
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
You are welcome. Good luck on your install!
Doyle257
658
Cheektowaga, NY
This is a good lookin install....but the dog...what Kind of dog is Darla? She's Beautiful!
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
I saw this truck about 3/4 of a mile away the other day and was like "woah.... a vehicle lit with green!" then realized it was this truck lol The green really does catch attention.
k-9 police xj
72
Portland, Oregon
Love the green Feniex lights. That truck looks great!
Not wanting to hijack the thread, but I'm using green Feniex lights on my Harley for marker/accent lighting. Love their products.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
The green really is awesome. Really. I think we will do demo vehicles in green white for now on. The green/white cannons are sick.
idk
