Finish RV45 bulb holders
coop359
495
USA Tennessee
IMG_3007.JPG I picked up a Unity RV45 with rust on the top of the bulb holders. I need to refinish it. Is it painted or some other type of finish? It also has the larger motor. Can these be purchased? Are parts available for the gear box?
Reactions: Windycity411
Jun 18, 2013
3,718
PA
I do not believe these were painted. I ended up pulling the rust off of my light with Naval Jelly and a wire brush.
UnityUSA
121
Chicago IL
Depending on how old the light is, it is either dual nickel chrome plated for newer version or cadmium plated for older versions.
Motors and gear boxes are no longer available. We had to discontinue the lights because we could no longer get motors from our supplier.
coop359
495
USA Tennessee
Thanks everyone. I'm going to make sure it works. Then I may try some silver colored paint. I have a couple of domes for it. Solid blue and red NOS. I do not have any spitfires.
Jackson223
11
East Coast
Those should shine up nicely once the rust is removed. FWIW I have found that most problems with motors on Unity beacons can be resolved by disassembling, cleaning, and lubing (I used sewing machine oil or 3 in 1 oil) them.
unityrv26
391
Michigan
View attachment 207874 I picked up a Unity RV45 with rust on the top of the bulb holders. I need to refinish it. Is it painted or some other type of finish? It also has the larger motor. Can these be purchased? Are parts available for the gear box?
I have a BRAND NEW never used RV-45. I used the pan and gear motor for my RV-26. So I don't need my bulb housing. You interested?? I also have a brand new amber dome.
Reactions: Mike10
QUICKONE
35
ARIZONA
Thanks for the tip.
I have an NOS RV15 that's dragging. I already lubed the transmission gear but No Joy.
GSPS629
