Found Alley and Takedown LEDs
94yj
60
ft worth tx
my alley lts now are the single mr 11 single halogen bulb and i want to switch over to the led design bulbs and can not find the double lt design and i was wondering if i could make my own by fab work to the original mr 11 bracket i have now and putting 2 lr 11 super leds in it has anyone done this please let me know tia
Sparky_911
Supporting Donor
May 15, 2013
2,666
Central Illinois
I was in your shoes a while back with my Freedom. The dual LR11 does use a different bracket and are muy expensive new. I was going to stick a single LR in each end and the MR housing would have needed a LOT of grinding, and it wouldn't guarantee fit. Plus if the job got botched I would be without any alleys until I got new MR housings. I ended up slapping a pair of Feniex T6 dummy heads in as a compromise.
See post number 34 on my thread if interested.
http://elightbars.org/forums/threads/freedom-on-07-silverado-update-11-11-15.64243/
94yj
60
ft worth tx
also do you think one lr 11 would put out that much light or would it require 2 lr 11s also what was the cost of the lights you mentioned thanks
Sparky_911
Supporting Donor
May 15, 2013
2,666
Central Illinois
Hmood
