Halogen vs. Strobe vs. LED
Alec R
50
eLightbars
What are the differences? Similarities? Which is best for what application?
Discuss!
Please keep it clean and organized, this forum section is heavily moderated to keep information organized. We're going to use content from these discussions to compile a helpful guide for users seeking information about products in this industry.
Highlander
16
Newfoundland, Canada
Just my 2 cents worth.
I've seen them all in operation and on different types of vehicles.
First; strobe lights - I found them very noticeable in low light/dark situations but hard to see in bright daylight. (I believe I read a report in some police magazine saying the same thing).
Second: LED lights - When you look at them straight on, they are VERY bright, and quite noticeable. However, they tend to lose a fair bit of their flash impact the higher (or lower) the lights are mounted and viewed. While these lights are great on a police car ( where the lights are level with a persons view) they are not as efficient on a tall fire truck except if your a distance off.
Third; Halogen rotating lights - In my opinion the best of the lights. Easily seen in the daylight, and due to the curvature of the reflectors, easily seen from almost any angle. In relation to strobe lights, which produces a very intense, but very brief flash, halogen lights build in intensity to the bright part of the flash, and then decrease in intensity. The beam moving back and forth across other objects, buildings, etc., also increases it's visibility.
Personally, if I was to design a lightbar, it would consist of both halogen and strobe lights, to get the best effects of both.
nerdly_dood
2,312
Georgia
Third; Halogen lights - In my opinion the best of the lights. Easily seen in the daylight, and due to the curvature of the reflectors, easily seen from almost any angle. In relation to strobe lights, which produces a very intense, but very brief flash, halogen lights build in intensity to the bright part of the flash, and then decrease in intensity. The beam moving back and forth across other objects, buildings, etc., also increases it's visibility.
This only applies to rotating halogen lights. As you said, rotating lights produce a brief but intense flash, which is good for shorter-range all-around visibility, but this isn't very effective for long-distance warning during the daytime. Stationary flashing halogen lights make up for that. If sufficient wattage is used - 28 or 35 is normal for smaller lights, but a bigger 50-watt light is ideal - stationary halogen lights are capable of warning motorists a mile away or more, even in direct sunlight. However, they aren't as good as strobes for short-range warning like getting people's attention in their peripheral vision at an intersection. With an appropriate flash pattern, LEDs can serve the same function as either a halogen flasher or a strobe, just not both - a large, bright LED light with slow, simple single-flash is just as good as a halogen flasher for long range, and a smaller one with a quick flash pattern lights up an intersection about as well as a strobe.
Rotating and flashing halogen lights tend to be the lowest-cost option for warning lights and provide excellent warning for the cost, but they do have some drawbacks. They require more maintenance: bulbs don't last as long as strobe tubes and power supplies or LEDs, but they are inexpensive and simple to replace, and the motors and gears can wear out and break over time. They also draw more current than strobes or LEDs, with a lightbar for a police car usually drawing somewhere between 15 and 30 amps, but possibly much more for the huge ones on fire trucks that have more rotators in them. Halogen lightbars are also usually taller than strobe or LED lightbars, leading to potentially worse fuel economy. But even with these drawbacks, halogen lightbars were the industry standard up until about ten years ago when LEDs began to replace them, and for good reason - they get people's attention, and you get a lot of light for not a lot of money.
Rotating LED lights are similar in effect if they actually use moving parts, but solid-state LEDs that simulate a rotating pattern generally produce a less intense flash, but the flash lasts a little longer to compensate. I haven't seen one myself yet so I can't vouch for it, but Whelen's new Rota-Beam R316 beacon appears to be a promising example of this. LED beacons that usually flash the entire beacon all at once but include "rotating" flash patterns, such as the Whelen L31, may be attractive, but this produces a warning signal that is significantly less visible, in all conditions, so for maximum effect, a flash pattern should be used that flashes the entire beacon as a single unit.
CodeMan
543
Central Florida
Using different manufacturers is like compairing Apples to Oranges.. when it comes to compairing the three.
So here is a video of all three in a single old skool STAR light bar showing the differences.
http://www.youtube.com/watch?v=cz8xVKDWzHo
Advancedstreet
