Help - Wiring Rigid Lights to Flash
Edmontonsecurity
194
Alberta canada
I want to know if this is possible. Along with how to do it.
I have two Rigid Industries Q series Lights, 2 feniex cannon flashers and 5 40 amp automotive relays.
Essentially what I want to do is the following
Switch 1 - Steady Burn On
Switch 2 - slow wig wag
Switch 3 - hyper wig wag (triggers with airhorn)
How can I do this with the feniex flashers and relays. Without worrying about back feeding the circuit.
I am very very new to relays. I in the past have wired standard 12 volt emergency lights but that was a simple:
Battery - circuit breaker - fuse block - switch - light
If anybody can help me out that would be awesome.
so essentially you will need 3 sets of power wires and grounds... (or tie all of the grounds together)
you would set mode 1 of the cannon flashers to steady. you will need 2 relays..
set mode 2 as slow single flash... 2 relays
set mode 3 as whatever pattern.. 2 relays
3 switches 1 for each mode...
each flasher lead wire will now be the trigger for 1 relay
each relay needs power, ground, trigger(+) and out put
sound good so far?
Only two relays are necessary.
are you going to use 20 resistors for 2 relays? But i guess that cannon flasher has its own built in system of seperating power for different modes.. in which case you would attach all 3 cannon flasher outputs as the trigger.. but thats not very fail safe if you loose a mode..
MtnMan
1,533
Eastern PA
So..... do I need 6 relays ? Lol
You're controlling two lights, so I can't see any reason to use more than two relays. Here's a basic circuit for what you're planning. The reverse-biased diodes protect against voltage spikes from the relay coils.
There's a possible complication if the Cannon flasher output is modulated. At least some Whelen LEDs use modulation for reduced output in steady-burn mode. I haven't checked any Feniex products.
jkelly
