Here's a little tip on cleaning rust
chief1562
5,840
Slaterville/NY
I'm in the process of redoing a Streethawk and the center plate and mounts for the speaker were rusty. If you don't have a sandblaster or don't want to use a power drill brush to clean with.
So I took one of those tubs you get when you're in the hospital or any tube will do depending on how big your metal will be.
And a parts cleaning brush, a stainless steel tooth brush, rubber gloves, magic eraser , Dawn and a bottle of The Works bathroom toilet cleaner.
I put the pieces in the tub poured the Works in you can add hot water too over it let it set for awhile (might want to make sure you have plenty of ventilation you're working with acid). Then take the brushes and start scrubbing parts brush will take it off the light rust and the stainless will do the rest. The wash with soap and use eraser to deactivate the acid.
Then I used Gun blue paste on it. Or you can paint.
Here's how they turned out. Might put a light coating of oil on it the same has I would if I had redone a barrel.
Torpedo
583
USA Fl
I also like soaking in vinegar, destroys rust overnight. Also heard scrubbing with crumpled up aluminum foil can clean rust safely from chrome but never tried that one.
chief1562
5,840
Slaterville/NY
twodogs603 said:
A stainless steel tooth brush? :undecided:
yeah they make nylon, brass, and stainless steel for gun cleaning and they look like a toothbrush.
And the stainless steel won't dissolve in the Works solution which is 20% hydrogen chloride.
chief1562
5,840
Slaterville/NY
LED said:
I also use a brush/scraper to get bubbles or chunks off then apply: Eastwood Rust Converter Quart Paint on & Stop Corrosion - Newegg.com, or something similar (same chemical). Works great.
If you can afford it. I was talking rust not paint.
And you can buy a quart bottle of The Works Toilet cleaner at the dollar store for a $1.00. Compared to your web site Eastwood is $29.99 a quart.
Also good one JD on the Pic for the stainless steel brush. :thumbsup:
NFD-102
1,083
NW Connecticut
Coca Cola does too! Soak over night, wipe the remnants with a towel and wah-lah.
JazzDad
5,165
USA
And once it's done the job, you can drink the Coke. Win-win! :thumbsup:
TCRescue
6
Kentucky
Scrubbing with aluminum foil does work on other types of metals but I haven't ever tried it on chrome
GSPS629
