High-Rise (Multi-Level) lights
lb101
40
new york
A couple of whelen bars that are done or almost done. First is a hwk 3 which has been restored and is fully operational the next is a hwk 1 which should be done soon. Next to be done is my McDermott which I could use some help if possible
deelony
185
LINY
what kind of help do you need with your mcdermott
lb101
40
new york
McDermott 6 pod motor works but pods are loose and I have no idea on the wire work looks like a rat went to town
Reactions: StEaLtH2
deelony
185
LINY
Older mcdermotts had a problems with the pods coming loose. simply tighten the nut by popping the plastic cover off below the pod and tighten. As for wiring all the bulbs are grounded to the lightbar frame. any wires coming from the arms put positive to and ground the bar.
deelony
185
LINY
I live right in Atlantic beach if you need any assistance
okc_f150
318
Oklahoma City
All these pictures and no video???
lb101
40
new york
That NCPDHP unit is a final generation (1998-2011) Crown Vic
Not the final whelen is releasing a new version I will be getting specs and prices soon here are some pictures.
deelony
185
LINY
that new highway bar in going to be the the vicinity of 5-6 grand i promise you
CHIEFOPS
1,533
NYC
More than 2 light modules per arm is overkill, all that's needed for an effective, coherent warning signal is 4 lights facing front and rear
lb101
40
new york
I say 3 per arm which the low end has plus the built-in ta. The nice thing is they have side protection in both positions.
deelony
185
LINY
that whelen one is a blob on video. nothing is synced
lafd55
2,393
New York, USA
And also The state police is running the new McDermott as well which is painted same color blue with a liberty
lb101
40
new york
taken while at McDermott only thing there are no forward facing led's on the McDermott bars
John211
40
Long Island, NY
Gentlemen, Visited the McDermott factory in Brooklyn recently. They have dozens of the old riser bars stacked up on shelves. When called for he restores them to original configuration and sells them for about $1800. He also makes the LED riser bars currently used by FDNY.
Jesseclark2448
