how do you make X pattern? plz help
JPBC4
98
NJ
Hey guys i'm brand new to the board. I have tried searching the forum and have not had much luck. I have 4 whelen tir3's( 2 blue 2 red) i'm mounting behind the grill and would like to sync them up to flash the x pattern. If anyone could guide me on how to wire them up properly it would be appreciated. I'm not sure if you have to connect all 4 sync wires or how or which phase the lights belong on...thanks again
THEFLASH
ALABAMA
1 connect all sync wires
2 place 2 of the lightheads on the same pattern that are diagonal from eachother
3 place the other 2 lightheads that are diagonal from eachother on the same pattern... then advance one pattern.
this should enable them to flash oppisate
1 2
3 4
1 and 4 should flash together
2 and 3 should flash together
twisted_metal
134
Toronto ON, Canada
set your lights to the pattern you want. set 2 to phase 1 and 2 to phase 2 see here (http://www.whelen.com/_AUTOMOTIVE/install/138/13838.pdf) to do that.
now install your lights in the color you want them to flash as such (below), wire the power and ground as usual, and connect all 4 sync wires together.
RED 1 2 BLUE
X
BLUE 2 1 RED or how ever your want the colors to be. Just follow the pattern with the 1's and 2's
JPBC4
98
NJ
1 2
3 4
thank you very much. I will give it a try tomorrow and let ya know.
JPBC4
98
NJ
RED 1 2 BLUE
X
thank guys!! appreciate the help
Jesseclark2448
