How to change light pattern on etl5000
Explorer dude
4
East coast
i have an etl5000 light bar. I am trying to change the flash pattern and I think I need to get to the breaker box? Where would this be located? And how do I change the pattern?
tsquale
Oct 12, 2010
10,537
Minnesota, USA
Thanks. But how do I advance the flash pattern?
Well if you actually looked at the link I posted...it shows on page one that the white wire is the pattern select wire. On page two it states: "Pattern Select - Momentarily activating the pattern select input will cause the activated light heads to advance one flash pattern. Also, when used in conjuntion with the cruise mode pattern select input will toggle the cruise mode setting."
Want me to read it out loud?
Positive side of the battery
Reactions: Tony P
idk
