How to turn a 24 or 28 VDC whelen beacon into a 12 VDC one
50theman
603
Virginia
rwo978 said:
How much did you pay for them?
I payed the list price like $29, but shipping killed me. It has a 12 volt motor with a resister hooked to it and a 24 volt bulb. To convert it all you do is change the bulb and splice the resistor out.
rwo978
ND, USA
Pull out the resistor???
I have these Whelen motors. They were in a 24 volt Guardian. If I were to take out the black resistors, they'd be converted back to 12 volt??
Anywho, I'm looking for a blue RB6 dome, so I got intrigued about possibly finding one cheap. But, if it's a crap shoot what I'll get.... I guess I'll bypass that headache.
50theman
603
Virginia
Yes, take the inline diode/resistor out of the red wire and it should convert the motor to 12 volt. The way you can check is for sure is to apply 12 volts to the motor directly.
rwo978
ND, USA
Thanks Man!! That worked. I'm not up on the 'finer' little parts of electronics (resistors, capacitors, diodes...). :eek: :eek::-x
rwo978
ND, USA
Sorry for adding all this to the other thread....
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
It was good info, that's why I split it.
emtanderson51
3,795
USA Massachusetts
thanks for the credit as I was baffled when I saw this and didmn't remember starting it....thought maybe I was "sundowning" yesterday lol
50theman
603
Virginia
No problem;), I actually found this out by accident. I then contacted a Whelen Technician (friend) and he told me they use 12 volts on all motors but just regulate the voltage by diodes or resistors and the light bulb.
GSPS629
