How-to Video : Retrofitting Feniex Cannons into fire apparatus strobe systems
Jan 19, 2012
304
Normal, IL
I made this quick and dirty... but for those that were considering replacing their strobe systems with an LED head, this may be an option you hadn't considered. I have done this to several fire apparatus and the difference is literally night and day. The Feniex Cannon is 2-3 times brighter than the OEM strobe and is considerably less expensive than replacing the strobe fixture with an LED fixture.
The video does a how to... then at the end a quick side-by-side comparison. As usual, the video doesn't do it justice, but you can see that even with the flat footprint of the Cannon, it still fills the entire housing. (There were concerns that it would just light a circle in the middle). One of the housings had water infiltration and all the chrome plating had come off (you'll see it in the video). That light is the light above the drivers side wheel well... you'll see no difference in light output and that the cannon fills the whole fixture.
Let me know what you think. I'm sure someone's got an opinion out there! :cool: We retrofitted this engine with 6 Feniex Cannons and with all the supplies, I think it cost a total of about $500 out the door. Prior to this, the OEM strobe packs were burning up about once every 2 months, and one of the rear 7"x9" strobes were DOA.
Reactions: Mrlunchbox
Caldwell205
