Howler wiring
Sep 13, 2010
761
Holland, Michigan
Morning all, I am in the middle of a install where I would like to use a whelen SLSA6 siren to control the operation of a whelen howler. I already programmed one of the 6 push buttons to momentary for triggering the howler. What I am wanting to do is use a 5 pin relay to complete the circuit between wires 7 and 14 in the howler harness. Here is a pic of what I am trying to achieve. My question is will it work? The siren is positive switched and the howler just needs the 2 wires to be connected for operation from what I can see. Any thoughts or other ways to go about it? Or how you may have done it with that siren?. I am trying to avoid using random push buttons. Thank you.
MtnMan
1,533
Eastern PA
Your circuit will work, but it’s not necessary. The SLSA6 has two outputs that can function as isolated NC/NO switches by moving the corresponding fuse. See section 5.2 of the manual. https://www.whelen.com/install/141/14130.pdf
You can also activate the Howler via ground switching (using wire 3), which makes things even simpler.
shues
NW Indiana
There are two relays built in to your 295SLSA6 that you could use for this purpose. Have a look at this excerpt from page 4 of the installation manual:
Source: https://www.whelen.com/install/141/14130.pdf
Edit: @MtnMan had the answer two minutes before me. Nice!
Reactions: MtnMan
Sep 13, 2010
761
Holland, Michigan
sadlad
