Legacy duo programming in Sapphire questions
Towguy84
5
Iowa
I'll start out by saying I'm a newbie at this so go easy. I can build my bar in WeCad but the file type doesn't register in Whelen Command. So when I just pick a legacy duo bar in Command, it has extra "modules" in the alley, TD and front outer positions. And which color is light one vs light 43 at module position one? I'm going to extract the program currently in the Sapphire so I can always go back to the current program.
NoLimitSquads
339
Minnesota
When in doubt, I just write a quick program and see what the lightbar does, thats an easy way to identify what modules and where they are. If you select the wrong modules, its not going to hurt anything. Ive programmed many legacy bars, and Ive had some react differently with where the takedowns are.
RS485
Supporting Donor
Aug 5, 2019
370
Central MA
Did you try "Export Lightbar" from WeCad? Its a menu option off the "File" menu which writes out a ".bxr" file. Then, it "Command" you'd click the "Import Device" button to read that file into your configuration.
Towguy84
5
Iowa
I did export and tried to import it from where the file was saved, but Command doesn't recognize the file.
Towguy84
5
Iowa
That's my next step, just wanted some better insight into the programming side. Eventually I'll grab some Trio modules for the front side.
Towguy84
5
Iowa
Ok I got it figured out. I actually just extracted the configuration out of the Sapphire, and made a duplicate so I could zero out the bar. Is there anyway to add the TA output to my box?
NoLimitSquads
339
Minnesota
Why do you need to add the TA output? Are you trying to add another TA in addition to the lightbar?
Towguy84
5
Iowa
Yes I want to add a non wecan TA to the front of my truck. I have another controller but I'd like to cut down on the number of extra devices in the truck.
htamboli
