Long shot...but
Elmira, ny
Would anyone that currently runs an ledx2100 with the ledx modules, AND has an arrowstick for the rear would they be able to take some pictures of how its wired up for me inside the bar??
Purchased some of the amber steady burn ledxs that auctionhunters has and am clueless how the wiring is connected to each head to do the arrowstick patterns.
Just have to find the cable to connect them all to the arrowstick controller i have, with hopes i dont need a narrowstick controller for it.
THANKS ALL :) :)
Doyle257
658
Cheektowaga, NY
In my Excalibur, all 8 modules are wired to a common (+) positive. The Arrowstik controller is a negative switching unit. My stick is setup in pairs, with the outer most modules being singles. ( center pair, right pair/left pair, right single/left single)
I hope that helps.
Elmira, ny
Does a little, all the wires on them have female connectors though, not sure if thats how it would come from factory, or if all the negative wires would be screwed to the frame, like the blue front ledx leds are.
I'll post a picture after work
Doyle257
658
Cheektowaga, NY
Do not ground the modules to the frame. The modules ground through the controller, because it is negative switched...as long as you are using a Code 3 Arrowstik/Narrowstik controller. Im not sure how the Whelen/Fedsig/etc are setup.
All of the modules should have female connections on them. I've seen people...improvise...and shove a ring connector into a female though.
Elmira, ny
Yup its a code 3 arrowstick/narrowstick controller.
They still have of the wiring with male connector still attached also, just confused to how they will get wired, all i have for wiring are the mx style arrowstick wire cables
Doyle257
658
Cheektowaga, NY
If I can't find cable, I make my own. 1-12ga(Halogen) or 1-14Ga(LED) in red and 5 18ga in Purple, Orange, Brown, Blue, and yellow, with heatshrink over the top.
Elmira, ny
Decided im gonna go different route and try and trade them for 8 blue ledxs that flash.
Apologize for the post :( . Guess im not really ready for led bars.
Doyle257
658
Cheektowaga, NY
LED and Halogen C3 Sticks are identical, aside from the modules themselves ;)
cawensel
