Looking for Rontan Attack information
bright_towguybran
4
CT
I won the bid on an (at the time no name unbranded) used light bar on eBay -through some hard research it’s a Rontan Attack Lightbar, I love the design, compact/slim design, light output for its size & number of LED’s, etc, but can hardly find any information or parts for it, I’m mainly trying to find a controller for traffic/directional controls as without one I have a few pattern selections, outer [cruise] lights both low power & high power, (no steady burn on the whole bar) and can split front/back using my DIY toggle panel. Any information would be appreciated!!
It has been some time, and countless hours spent messing with the bar, searching forums, expired host links, I am lost!! My bar will not operate properly, even after "polling" the bar, I ordered a ICM20 as I could find one, and everything pointed to it being my problem, but it does not seem to communicate with the bar, I'm at a loss, any help would be appreciated!
tsquale
Oct 12, 2010
10,560
Minnesota, USA
do you have the manual for even the ICM40? I have a Rontan attack lightbar and have tried polling the bar but I was messing with it and now it's all out of whack, cruise lights are in different spots in the bar, flashing is not correct, I got an ICM20 on eBay as it was said to be my only chance of better communicating with the bar, but after hooking it up, I can't get it to do anything, any help would be appreciated!!! of course my Whelen bar died so I'm relying on this Rontan attack bar for the time being, (stupidly)
I'm not sure that there ever was a manual for the ICM40 or ICM20 as the modules themselves have the pinouts listed on them. If your bar isn't working while hooked up to it you may have 1. Hooked it up incorrectly 2. Blown a fuse in the bar. 3. Fried the bar internally or a host full of other things. I have attached the manual for a Winglux bar as it describes going through polling and some other items to try without the ICM to see if you can get it squared away.
  • rontan winglux.pdf
Reactions: bright_towguybran
aidey1234
