Greetings!
Was wondering if the minds here may have an answer to my issue before i send my unit back to Whelen for diagnosis and repair.
I have a Whelen 295HFSA1 Siren unit wired to a pair of Federal Signal Dynamax Speakers. All the wiring was done exactly as shown in the Whelen instructions. I used all the required wire sizes as well and everything is soldered and heat shrunk, no crimps. The issue is the output volume is not even close to what 200 watts should sound like. We compared it next to another similar setup and the volume is half at best. The diagnostix lights are both lighting showing the speakers are good and you can put your hand on the speakers and feel them working. The volume control is all the way up. I called Whelen and they said you could have a weak amplifier or even a blown amplifier. Does anybody else agree? In a likley related note, the PA mic now suddenly does not work. You key the mic and no sound comes out of the speakers.
