Lp6000 cal
denko3
866
SLOVENIA,EUROPE
Hey guys!
can someone please help me and tell me which bulbs had lp6000 CAL in the bar and what was the configuration?
any pics would be great.....
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
denko3 said:
Hey guys!
There is no single CA setup for an LP 6000. The red steady light was a full sized stationary light with a 50w bulb I believe.
JennyCop
2,021
Sunny Arizona
I dont think a full size stationary bulb would fit in the LP6000 I think you are thinking of the XL model.
Lol sorry John, I was thinking full size sealed beam, Denko John is correct it would have a stationary light, the type used as the takedowns or flashers with a 50w bulb.
badge22
934
MI, United States
I THINK they used a stationary reflector that had a special coated reflector for the front stationary RED. Kinda looked liked it was unpolished.
Benno
370
Germany
The stationary reflector is not coated.
The reflector is frosted! Except for a small area in the middle (behind the Typ795 bulb).
The Setup of the LP is:
Alley-light - rotator - diamond mirror - steadyburn/rear-flasher - speaker center - front- /rea-flasher - takedown/half diamond mirror - rotator - alley-light
badge22
934
MI, United States
Ok, so if you "frost" something, are you not putting a coating on it? :yes:
Benno
370
Germany
Not necessarily! :no:
Looks like sand blasted. That´s the easiest way to "frost" something.
denko3
866
SLOVENIA,EUROPE
WOW never seen a stationary reflector like that,was it a factory made? it looks like there it was spray it after they made it. :)
thanks for set-up Benno but is this the only setup or was there any other maybe?
John,so the bulb for CAL red is 50W isn't this too hard usually the CAL in lightbars were less the 30W,what do you think? i got the 50W in mini vector and it's very strong.
yes Jenny i now what you ment about stationary light in XL.... :)
folks what about domes red and blue set-up?
and is there a possibility to change the lp rotator reflector with mx or xl reflector is it hard,what you must take off if i want to do that?
is it just a ring or anything else maybe?
jdh
Geneva, FL
I have seen set ups with, (Pass to Driver) alley, rotator, blue steady burn(rear blue flasher), sting ray, speaker cover, sting ray, red steady burn(amber rear flasher), rotator, alley.
And that is a weird reflector. i have worked on thousands of LP6000 and I have never seen one quite like that.
denko3
866
SLOVENIA,EUROPE
thanks for this set-up too! maybe was this set-up old CHP cars??????? :)
yes i see the first time sended lp reflector????
badge22
934
MI, United States
Sandblasting is not frosting something. I have never seen a cake sandblasted.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
I have a factory LP CA setup with the steady burn being a fully polished reflector too... so they used a few things... I have also seen both used in the XL.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
denko3 said:
can someone list some pics from domes which is the original set-up?
There is no one CA setup...
Most had outer rotators front diver steady red, front passenger takedown.. other options varied a lot. Any LP that has full size flashers or takedowns could have one replaced with a steady burn.
denko3
866
SLOVENIA,EUROPE
isn't there the reat cut out amber flashers in domes?
jdh
Geneva, FL
The CAL LP6000 that I called out in my above post has solid colored domes with bullet cutouts for the alleys and 1 amber cutout in the red dome to the rear.
Benno
370
Germany
\ said:
...And that is a weird reflector. i have worked on thousands of LP6000 and I have never seen one quite like that.
I think Code3 called the Reflektor "Stationary Partially Textured Reflector Assembly (S45023M)" or "50w Partially Textured Stationary Module (S45024M)". But i´m not sure!
My LP has blue/red domes with small bull´s eyes for alley and one large bull´s eye for takedown.
chief1562
5,840
Slaterville/NY
:duh:
ford-dealer
857
San Antonio
If my memory is correct, didn't CA bars require the black plastic siren speaker housing that allowed a NO-LP style speaker to be installed? I am thinking I remember seeing a CA Title XIII designation on that option in the original sales brochure.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
It had a Ca compliant speaker available... but many had no speaker at all. CA LP were just any LP with at least 2, usually 4, fullsized stationary reflectors.... 1 was steady burn and under a red filter or dome... and at least 1 was almost always a rear amber flasher. Add in the fact that you could use reflector mounted or reflector surrounding filters or colored domes with cutouts... the setups were endless. LPs were under rated bars.
6236 was a commonly "CA converted bar", as were 6296 and 6349 if one were into stingrays...
lite-em-up
116
Eastern Missouri
Your memory IS correct. In order for a LP BAR Mounted speaker to meet Cal requirements, you must use the black "class A" speaker cover. It resembled a JetSonic speaker in a way. The regular chrome LP speaker cover required the speaker bell to be cut at an angle in order to fit under the cover. The cutting of the bell no longer meets the Class A requirements.
As for the stationary light, In order to TRULY meet Cal requirements the red steady burn required the frosted stationary light. The "frosting" was a special coating that was placed on the reflector by the supplier to Code-3. Instead of the smooth, highly polished reflector it would be rough and dull in finish. The pic above is the correct stationary light.
From the sales brochure:
Many of the bars that I saw go out of the factory to Cal were either under a red lens with clear bulls-eye to the rear for the amber flashing light. The stationary light behind the bulls-eye had an amber filter on it.
OR
Clear lenses with colored filters
Reactions: Wigwam700
ford-dealer
857
San Antonio
That is the exact brochure I remembered seeing it in. :thumbsup:
NPS Ranger
Penn's Woods
You gotta love Kalifornia, trimming a speaker bell as used in the other 49 states doesn't meet their rules so a whole new speaker cover is required just for their state... but yet a single red spotlight is perfectly safe and adequate by itself as a warning light.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
Here's mine, all the stationary lights are frosted. There was never a speaker mounted. It used to have stingrays...
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
denko3 said:
was the speaker housing custom made then?
No.. it's just a regular grill with nothing behind it. The speaker for this unit was elsewhere... probably on a push bumper.
denko3
866
SLOVENIA,EUROPE
would like to see one with solid red and blue domes if someone will post a pic maybe,i hope.....someone????
fireman5340
