fireman658
So a neighboring department got a Deuce a while back for a tanker from the conservation dept. They want lights on it. They had bought a 24v to 12v converter to run the lights. I fixed up an all red Vista strobe bar for them. I finally went down the other night to hook it up. It's pretty simple. Run the power IN wire from the converter to the battery, ground it (which they did to the cab), then run your 12v power out wire to whatever needs 12 volts. Done. So I ran the 12v out wire to a toggle switch that I put on the steering column, then ran the power wire from the bar to the other side of the toggle switch. Great. Flip the switch and give an epileptic a seizure. Success!!!!! But wait.............. Turn the switch off, wait a minute, turn it back on and back off for a minute and on once more and nothing. It will never turn on again after about the 3rd time unless you unhook the power wire for the converter from the battery and re-apply it. So when it quits working you can leave the toggle switch on and unhook the converter power wire from the battery and instantly touch it back to the positive post of the battery and it's all blinky again. You follow me????
