SOLD Model 14, Federal Sign and Signal dual sealed beam beacon
Minnesota
Lights of this type/vintage are not my standard collectable item so I am listing it here. I do not know much of anything about the specs of the light (what is factory and what is not). I was told that the dome and magnetic plate on the bottom are not factory.
Here is what I do know...
It runs great. The dome does nor have any cracks but has a good ammount of scratches. The guy I got it from is retired and said he used it on his wrecker. I put on new wire leads, good for running on the display. It has a thick heavy magnetic plate on the bottom. It appears to be thick strips attached to eachother and trimmed into a circle to fit the light.
Inside the base and gear area was pretty dirty. I disassembled the light to clean it up. I scrubbed the old sticky layer of grease and grime from the gearcage parts that make contact when moving (bushings, washers, C clips), dried them off, lightly greased the contact surfaces and reassembled. I did not wipe down or clean the bulbs, bulb holder assembly or motor.
Looking for $100 plus the shipping and packing. (Saw a couple on fleabay go for a lot more so rather then reaching for the stars or haggling, this seems reasonable).
Screenshot_2021-10-11-22-12-16.pngScreenshot_2021-10-11-22-12-44.pngScreenshot_2021-10-11-22-11-51.pngScreenshot_2021-10-11-22-12-40.png
Reactions: kadetklapp
jdh
Geneva, FL
Someone correct me if im wrong, but I think that dome belongs on the model 17??? I thought the 14 had the flat top dome.
stansdds
3,540
U.S.A., Virginia
The large diameter dome for the Models 17, 173, 174, 175, 176, and Titan will fit the Model 14.
bjwilliams
