Mounting a Federal Q in a Ford C8000
DFD1994
24
DFW Metroplex
I am wondering if anyone happens to have any knowledge or experience on mounting a Federal Q into the grille of a Ford C8000. My engine (a 1985) originally came with a grille mounted CP100 which I have removed in hopes of retrofitting the mounting hole to accept the Q instead. The Q I purchased came off of a slightly newer (87 I believe) Ford C-Series so I know this is doable. The main body of the siren fits well, my struggle is in fitting the brake solenoid and making sure it is securely a-fixed to the truck. I have not been able to find any images of how these were originally mounted in this type of truck so hoping the hive mind will be able to help! I am attaching a couple shots of the hole where the CP100 was mounted as it exists right now, however I realize it may need to be altered.IMG_7663.jpg
Bvfa23
147
Depew, New York
What style bracket is on the Q now? They make pedestal and then a “flush” mount bracketry for different applications
DFD1994
24
DFW Metroplex
DFD1994
24
DFW Metroplex
Take a look at the link below and the Q-MT mount, that’s what you’ll need
https://www.fedsig.com/product/q-siren
Excellent, I saw this when I was looking at wiring diagrams but somehow blanked on it now that I have gotten around to installing. Do you know how the brake solenoid interfaces with the bracket? I haven't been able to find a picture or diagram showing the brake installed, only the Q itself.
Bvfa23
147
Depew, New York
The brake shouldn’t interfere with that mount at all, the brake typically mounts right to the side of the siren
DFD1994
24
DFW Metroplex
Okay, I'll have to just bite the bullet and get the bracket. In my understanding the brake is in the pedestal so the bolts and mounting for the Q-MT will use the mounting points for the brake/pedestal
Bvfa23
147
Depew, New York
Hmmmmm Federal may have changed their design in the years, the current models the brake attached directly to the side of the motor of the siren
DFD1994
24
DFW Metroplex
I will have to get a look at a current one somehow and see how the brake solenoid works on it. I'll post updates here as I go just in case anyone else can someday benefit from it.
jkelly
