mPower Custom Table
tuckerm
444
Wisconsin
In the manual for these lights, it mentions a custom table option. Is this something user configurable? I'd like something similar to Red Wire: Flash Color 1; Red/White Wire: Flash Color 2; White Wire: Steady Burn.
Thanks.
tuckerm
444
Wisconsin
Without downloading or purchasing anything yet....can I configure the wires like what I mentioned above with it? Or am I still limited?
sykoball01
7
Texas
With the programmer, you can set up the light as you described, plus more if needed, essentially you can have 6 different "modes" but you are limited to 1 flash pattern for the light. So you cannot setup a different flash pattern between the red wire and red/white wire and so on. Hopefully they will update the firmware/software to allow this in the future.
tuckerm
444
Wisconsin
You've been extremely helpful. This will really help my install plan.
Final question.... I see it's compatible with mpower and intersectors, what about the nForces?
Thank you for all of your help!
sykoball01
7
Texas
Unfortunately the nforce are not compatible. This was my hope as well but right now only mpowers, intersectors and undercovers are compatible. Glad I could help :)
Reactions: tuckerm
Oct 20, 2010
809
Rehoboth, MA
Also fyi, the white wire cannot operate by itself. It only works in combination with the other two wires.
GSPS629
