MX7000 missing parts. need help.
Skidmark
15
Illinois
hello guys. im new to the whole lightbar biz but i just obtained a Codse 3 mx7000. i had done some tesing and was able to activate the top driver/passenger rotators(Red wires), the center rotators(Blue wires), and the intersection rotators(white wires). these were easy by crossing 12v from ground to the respective wire. now the bar is equipped with 2 sets of strobe tubes located in the ends. ( believe that is the proper names) when they wouldn't turn on i opened it up to find the thing only had the wiring harness to the running rotators. the tubes were just sitting there disconnected. from what i could find im missing a strobe powersupply to run these, from what i can gather the outputs go the the strobes. ground to ground and positive to battery positive obviously. but then theres this 3 wire control plug that i have no idea where it goes to. i cant find any helpful documentation that tells me what i need to geth this bar fully functional again. any help would be greatly appreciated
Dave F
Moderator
Sep 13, 2015
1,343
Berks County, PA
You would need a Code 3 MX7000 MX4HD Strobe Power Supply
PN: S80305
like the one shown
Skidmark
15
Illinois
Okay. Is there anything ide need on top of the powersupply? From the manual i was reading it showed a 3 pin control plug on top of a + and - connection. Couldn’t find any sort of wiring guide out there to make sense of it.
Dave F
Moderator
Sep 13, 2015
1,343
Berks County, PA
i didnt scroll through all the pages, but perhaps this manual might help
Skidmark
15
Illinois
Yeah thats the one i looked at. It shows the power supply on pg 18, showing the “control harness”, but couldnt find anything as to where it all goes
Dave F
Moderator
Sep 13, 2015
1,343
Berks County, PA
Ive sent some PMs to members I know that have working knowledge about the strobe versions, I myself have never had/used the strobe versions. Hopefully one of them can chime in and help
Skidmark
15
Illinois
Turned out while i was tearing it down to clean that these tubes are not stock code 3 strobe tubes. Im removing them from the bar until i figure out what to do.
Reactions: Dave F
CD3
411
USA, CA
Are your strobe tubes have the rubber ends that pop into the reflectors and have a red wire coming out of one end and the black & white wire out of the other end?
htamboli
