need help with the procedure for feniex fusion to make them alternate of each other
billm
20
texas
need help with the procedure for feniex fusion to make the flashes IE 1 lead and 1 follow alternate of each other can someone give me directions on how to do it thanks
fp13-2
359
Harrisburg, PA
From the manual (assuming it's a Fusion Surface Mount).
"E) For the light heads to alternate, one light head must be set as master and the other as slave on the mode wire intended for use. To do so, hold the blue (flash pattern changer) wire to ground for 3 seconds. If all LEDs turn on, this indicates master mode. If no LEDs turn on, this indicates slave mode."
Reactions: Dave F and billm
jkelly
