New Grote Tag Created
Skulldigger
1,740
Georgia / USA
I found a cheap way to create Grote tags and it works great ! Here is my before.
217352
Here is the afters
217354
217353
What do you think? I copied the Grote from their website, then was able to match the fonts for the remaining lettering. Took me about 3 tries moving things and resizing to get an exact match, but it fits pretty much right over the existing.
Skulldigger
1,740
Georgia / USA
So I only need your decal. I have the sticker foil.
The decal I have is clear. On the 7624 it's a metal tag. It will have the look of what ever is under it showing through. If you have faded lettering it may ghost behind it if not perfectly matched or aligned. I would remove the old before applying this. If you apply this sticker to foil it should look right.
la_canuck
