Newb wiring up a Wolo
shues
NW Indiana
The power supply you've linked is rated to supply only 2 amps at 12 volts. It's insufficient for that beacon.
Each of the two sealed beam lamps requires nearly 5 amps, plus substantially more instantaneous current when first switched on. The motor will also require about 1 amp, and several amps for a moment when first switched on.
With that said, using a small 12-volt alarm panel battery would be sufficient to run the beacon briefly, and the power supply you linked would probably be fine for charging the battery.
Trebeck
3
Canada
Hey Shues
Thanks so much for the wisdom. I'd love to run these off a power bar inside my arcade. Can you recommend a power source?
@shues that lil power supply doesn't provide charging voltage. Chargers are 13.8 - 14.7 if it's only straight 12v it wouldn't get a battery past the point of dead :)
Trebeck
3
Canada
Could a wonderful person point me in the right direction and show me a good power supply I can use? Any favorite online stores or is Amazon just as good?
Thanks all
Da-Sarge
393
Canada
I use computer ATX power supplies you can get them pretty cheap that can provide plenty of amps on 12 volt plus can supply a good amount of juice on 5 volt as well for driving 5 volt devices in the arcade cabinet i drive full lightbars among many other high current 12 volt devices via computer power supplys the beauty is they are standardized so replacement is a standard off the shelf part thats easy to find
Gasman
