omega 9000 siren
Chris-donato
10
New Jersey
hello i was wondering if a omega siren can work with a whelen lightbar like a justice lightbar or a liberty lightbar. and also with federal signal's newer lightbars.
Thank you
shues
NW Indiana
The Omega 9000 is a great switchbox. It has a three-position progressive slider and can accommodate up to six additional switches. You should be able to use it with any lightbar. Depending on the lightbar you choose, a Whelen WeCan Control Point or Federal Signal Serial Interface Module may be needed to provide discrete 12-volt inputs to control the bar.
Thanks to member EVModules, the Omega 9000 install manual is here: https://docs.google.com/viewer?a=v&...TAtZjdmYi00NThkLTk3OWYtNmJmOTk1OTIzOTYz&hl=en
Another copy of the manual is here: https://www.scribd.com/document/372566625/Unitrol-Omega-9000-Installation-Instructions
An archive copy of the manual is here: https://web.archive.org/web/2018022...nloadFile&id=1018270379e4c43d86703e33e83592b5
Chris-donato
10
New Jersey
So if I use a regular liberty lightbar it work the same as if it was a whelen control box I just want to make sure before I go out and put money down for a light bar
shues
NW Indiana
If the Liberty you're looking at requires a Whelen control box, something like the MPC01, then the Omega 9000 will not work for you.
Chris-donato
10
New Jersey
Sorry to keep bothering you but can you check this please and is it compatible with the omega siren
htamboli
