Programming 4200DL w/ a power button (see example)
jabbeaux
24
NY
I’ve been scratching my head at this video, see 26sec mark. Appears they wired + programmed 4200DL to only “power on” when a single button is pressed.
Truck is on. 4200DL isn’t..or doesn’t seem so? Button on keypad w/ power sticker is pressed, then 4200DL is on. How is the 4200 recognizing the input if the keypad hasn’t booted? I like the idea of killing lights/keys on the unit until Power button pressed....but how did they do this?
tsquale
Oct 12, 2010
10,550
Minnesota, USA
I have never used at 4200, but is it possible that they have the "power button" only controlling a trigger for the back lighting that would normally be wired in to the ignition?
whatevah
388
Delaware, USA
The control head is dead if the main module doesn't have power & ignition input. The power button likely just activates the backlight input and maybe relays for siren power or something similar.
jabbeaux
24
NY
Thank you (both)! I recall thinking I had to feed power for night OR day, I guess those are optional?
@whatevah - you'll appreciate this. 2 days of no driving he jeep in winter kills the battery. I've got the brain hooked to control wires, but main power for each light goes through a BlueSea box. Did you put an ignition-switched relay before the BlueSea, to avoid that battery drain?
Avoiding battery drain was my initial idea when I saw this video.
whatevah
388
Delaware, USA
I had a bit of battery drain that I think improved when I added a relay between my BlueSea box (supplied my radios, 4200, fridge and air compressor) and 4200, but the main drain was honestly the fridge that lived in the Jeep almost year-round.
Btw, the JK is gone... currently waiting for supplies to arrive to light up a Gladiator. I think I'm going to use one button as a backlight kill, have the ignition trigger jumpered to the backlight input through a relay's NC terminal and have a 4200 output switch the relay to its (empty) NO terminal.
jabbeaux
24
NY
Thanks @whatevah, sounds like an ignition-switched relay before the Blue Sea fuse box is my solution. As for this thread's orig question, sounds like I just tie one button's output into the NIGHT's port. Shockingly involves less voodoo than I expected.
Good luck with the Gladiator, can't wait to see how you top your Wrangler's setup!
Advancedstreet
