Progressive Slide Switch Configurations
andrewsim
316
Northeastern, IL
A topic came up in my thread on my new vehicle and I wanted some insight across the board. This is my first time with a slide switch, sooo:
How do people set up their 4 position progressive slide switches??
Mine is setup to always be 360 degree but increase number of lights and rate of the flash patterns (Carbide). I would like some ideas and insight. I don't do traffic stops, but I'm interested across the board and maybe this will help someone else.
hitman38367
881
West Tennessee, USA
Being on a fire dept. and not doing traffic stops, I've always had mine set up like this...
Pos. 1- minimal lighting all around such as TLF and only two single alternating lightheads on a single flash pattern in the back and maybe one set of HAWs in the front.
Pos. 2- All lightheads on except the TLF, some of the grille lights, and any clear lightheads, in a slow alternating single or double flash pattern.
Pos. 3- Rock-n-roll, full tilt boogie...Christmas tree time. Usually a faster, more complex flash pattern on all lights here.
All lights synced if possible, same color then alternate color so no mixing or blurring of colors occur.
I've seen other vehicles with pos.1- all rear, pos. 2- sides, minimal front, plus all rear, and pos. 3- all on.
10-75_Da_Box
164
Wappingers Falls
For my POV I'm installing an older CenCom Red that was given to me. Lights I am running are a Dual Talon B/B on the Dash. Ion Duo's Blue and Amber on the front bumper (Truck). The rear is a 4 head SOS stick B/A in the rear window and Vertex's in the reverse lights Blue and Amber.
Pos.1 Rear only.
Pos.2 Rear, Duo's flashing in amber. (For stuff not related to FD)
Pos.3 Rear, Dual Talon, and Duo's flashing blue (FD Response)
I also have one of the buttons programmed so that the ions will flash both blue and amber if I'm parked on the side of the road at a call.
CHIEFOPS
1,533
NYC
If the vehicle responds to the emergency scene-
Pos 1: REAR only
Pos 2: REAR + PERIMETER flashing (any side lights, grill lights)
Pos 3: RESPONSE: REAR + PERIMETER + FRONT & ROOF (flashing headlights, intersection lights/hideaways, dash light, roof/360 light)
Reactions: 10-75_Da_Box
im a switch freak... back when i had a street hawg, it was the only thing on my slider...
1. was 4 rotators
2. center
3. all flashers
in my escape i have
1. setup as "power on" for siren, cig outlet which has gps, dashlight power, backlighting etc
2. mode 1 appolos front
3. mode 2 appolos front
although my mini 4200 isnt a "slider per say" its setup for the rear "like a slider"
1. all ambers
2. all reds
3. balls to the wall amber and reds, (mode 3 cannons, mode 2, fusions)
Bvfa23
147
Depew, New York
In both the vehicles I use for FD response as an Asst Chief -
SS1 - Rear ONLY
SS2 - Rear, Sides and Front all BUT White
SS2 - Rear, Sides, Front and HLF/Any other white toward front
htamboli
