Question about Sound Off Ghost
RL1
1,650
Ga
For those of you who have put Ghost's under a side mirror, how did you run the wires? I am thinking of adding a set to my work Impala but don't want the wires just flopping around. Thanks!
C17LVFD
Harrisburg, PA
I installed a set under some Ford Explorer mirrors. Most mirror mounted lighting is a PITA to install. You have to pull off the inside door panel, remove the mirror, mount the light, run the wiring, and then close everything back up... They're time intensive, but turn out very nicely :D I would pull up some install instructions from Whelen on their mirrorbeams for impalas. There's the instructions to disassemble the door and mirror, then just run the Ghosts and reinstall. No point in reinventing the wheel...
Good Luck!
Seth
RL1
1,650
Ga
Sounds like a good idea. I was so stuck on the Ghosts I didn't even think of looking at the MB manual. Thanks!
jkelly
