Question about the feniex typhoon
Mar 17, 2013
16
Virginia
My department is currently pricing a new emergency package for a brush truck.
On the front of it were looking to get the strobes n more eflood 7200 that has the warning lights built-in to it. I know that bar needs a flasher.
Will the integrated flasher in the feniex typhoon be enough to drive the emergency lights in that bar or do I need a dedicated flasher for that bar?
jmamrak
382
Lagrange KY
The SNM 7200 is rated 8 amps.
The Fenix is rated only 3.5 amps per output.
Using output 1 and 2 (those are the built in flasher outputs) would give you only 7 amps and the bar is rated for 8 amps.
The cheapest way would be to buy relays or a flasher would work as well.
Mar 17, 2013
16
Virginia
That makes sense. So we should just purchase it's own dedicated flasher and be done with it.
Will the flasher in the tyhpoon drive headlights on a 05 Ford f250?
jmamrak
382
Lagrange KY
Looks like that truck uses an H13 bulb from my research only 1 bulb uses 4.3 amps so the answer is no.
Big JW
