Question regarding SoundOff nForce tri color exterior mount lightheads
daniel_medic
139
Afghanistan
Hi Guys
I need some help with the nForce tri color units.
I was under the impression you could select which colors would flash for certain modes. I want to set it so that in primary mode it flashes red/white with white as take downs. and in another mode would like it to flash red/blue/white with white as take down as the area I mostly work allows red/white and no blue. but another area which I work less frequently allows blue.
I cant seem to figure out how to get it set like that. is it possible?
Oct 9, 2014
17
Hudsonville, MI
daniel_medic,
Setting up different flash modes can be done. The flash mode would have to be configured under the flash patterns tab. Then the corresponding flash pattern mode would have to be activated by an input which has to be configured on the breakout box inputs tab. So whenever the wire you selected to activate the flash pattern mode gets 12 volts on it, the lights will change flash patterns to mode 2, 3 or 4 depending on the mode you configured and have activated. If the mode has not been configured it will flash the default flash pattern.
daniel_medic
139
Afghanistan
daniel_medic,
Hi Justin
Im still struggling to get it to run the way I want. It seems as if it runs either color 1 and 2 or 1, 2 and 3.
I cant get a mode to run without color 1 being blue.
woobatu
