Red AM 600 comparison..
We saw sparkys review on the blue
.. here's my 1st impression and vids I just took....
So I ordered Red mag mount from U B L..last Saturday... I got a confirmation that my order was placed but never a shipment email... Today I checked their site and it stated "partial order sent". I was thinking ok what does that mean?
Tonight I checked my hidey hole were my mailman places my packages and there it was.
The box it came in.
Some assembly,dissasembly, and reassembly required...
The mounting plate was not assembled right. The "tabs" that go in the wire exit hole did not line up properly and were 120 degrees off... I had to unscrew the mounting plate turn it and reassemble....
The mounting plate screws are:
A) either wrong size or type
B) to long
The magnet doesn't hold worth a flip... I may reverse engineer it later with a bigger one as it feels like a 10lb pull but it's the size of a 50lb I was told it is not rated to go above 30mph... It'd be hard pressed to push 15 lol... I'm only using it for parades and stationary use for now....
Night time vids..... Turn monitors sideways ..
By itself...
Red vs code 3 green.... I selected the rotate/flash patterns for these...
AM600 vs halogen red firebeam.... Even though the led appears brighter there's nothing like that halogen pop you see
And finally, I added the dash light which wiped them both out..... To the front... Except that pop from the firebeam...
Overall, I'm not overly impressed...but it seems decent for the price... It's slightly larger than the code 3 beacon and it's 3 times bigger than the firebeam... I'll try to do daytime vids tommorow
Must have fallen out of the box last night as they were under the ride...KIMG0599.JPG
Now to swap them out ....
Reactions: OliverD and Tony P
Sparky_911
Supporting Donor
May 15, 2013
2,661
Central Illinois
I'd like to see a SNM $100 dollar beacon compared to othe brands of the same cost......I've seen SNM vidz of their beacon, looks good.
A size comparison of the right screws...
And then right ones in....
MAGNET UPDATE..
ok so your results will vary but I put the beacon on the ride for the Christmas parade Sunday... because i have another parade Friday night i just decided to leave it on there.. Cautious as to its reliability i have become quite surprised...
I drive 12 - 14 miles to work a day depending on which highway i take (backwoods or "main") on top of the 8 - 10 miles it takes me to get to any food place in the next town because where i work doesnt have night time food service.
the back woods highway has sharp curve,s steep elevation increases and decreases sometimes in the same mile... I have not exceeded 60mph on this highway and the beacon has not budged..
I passed someone on the mostly 4 lane highway the other day and even passed a school bus (no sign out traveling 50 in a 55 on a 4 lane). When i got off one night i pushed 75 and still no movement from the beacon...
now let me say this, my roof on the escape is mostly flat. I have a small antenna directly in front of the beacon which may be helping the wind to "go around" it so its not getting a direct hit...
I have not taken it on the Interstate (nor would i have a need to... lol)KIMG0616.JPG
Sparky_911
Supporting Donor
May 15, 2013
2,661
Central Illinois
Jared I think I found a solution to your lack of stick-um when it comes to magnet mounts.
I went to the local Harbor Freight and picked up 3 of these babies...
A little Scotch brand (read: stretchy) electrical tape and voila....75lbs of magnetic force.
Only $15. (Plus I got a free magnetic parts tray with a coupon). Cheaper than their mount.
Video to follow on the review thread I posted. Didn't have chance to road test today.
Reactions: Tony P
that will work but my goal is to just find a bigger magnet than whats already on there.. this is the second beacon i have with the "mag/vac" suction method and it does work well
K9_1468
5
Tennessee
I recently got one for my off duty gigs, and I am not impressed with it at all. To me the magnet was the biggest joke ever
jeaustin924
