billforbush
Im trying to activate the functions of a Federal MS400U siren (which uses switched ground for each function), with a switched hot circuit. Could someone please advise where each wire would go on a relay so that when the hot switch is energized, the relay outputs a switched ground signal? Thank you very much.
