Remoting a Whelen rotary
Dudie
11
Riverdale, NY
Hi I have an older Whelen 295SL100. I don't have anywhere to put it so I'd like to remote the rotary. It looks like it's soldered onto the circuit board. My thinking is I can remove the rotary, solder extension wires to each solder point/lead and then mount the rotary somewhere else.
Will it work?
7d9_z28
3,048
West Michigan
Yes, I did the same exact thing with a 295hfsa1, worked fine. I do agree that finding a remote siren to better suit your needs would be optimal.
Dudie
11
Riverdale, NY
Except that I don't want a remote panel. I JUST want the rotary remote so I can hide it in the car. Even if I got a new siren with a remote I'd still want to remote the rotary. What gauge wire did you use?
Dudie
11
Riverdale, NY
Except that I don't want a remote panel. I JUST want the rotary remote so I can hide it in the car. Even if I got a new siren with a remote I'd still want to rremote the rotary. What gauge wire did you use?
Dudie
11
Riverdale, NY
7d9_z28
3,048
West Michigan
I still had to remote mount the power switch for the siren, the volume knob, and the manual and air horn buttons. But for the knob I just used some small wire I had on hand, I want to say it was 16awg but could have been 18awg.
Dudie
11
Riverdale, NY
Perfect. I'm going to leave the power running full time, don't need to touch the volume and already have the HF remoted to a Feniex 4200 Mini (1 switch). Don't need both the HF AND manual operation.
Dudie
11
Riverdale, NY
That would be insanely awesome, but also doesn't work with newer cars since the HVAC rotary spins endlessly. Would be fun, but I'm happy installing the rotary wherever.
Hmood
